lldp.FA.AddPortToVLANFail
Description
An attempt was made to add a list of ports to a VLAN, but the operation did not succeed.
Remedy
The CLI command "show vlan fabric attach assignments" will display VLAN and NSI values known to Fabric Attach for each port . Output from the "show vlan <vlan>" command will include a list of ports that have been added to that VLAN. From these, it is possible to determine which port(s) did not get added, though unless the VLAN manager logs a message, there is no way to tell why the failure occurred.
Severity
Warning
Message Text
Failed to add %numPorts% ports to VLAN %vlanTag%.
Message Parameters
Name Type
vlanTag VLAN-tag
numPorts sInt32
